Polishing Foam Pads
Churchill Paints foam pads consist of a range of polishing and compounding foams suitable for the most popular and modern paint systems. It's unique curved rear edge helps to control the pressure and prevents the foam from collapsing and thus eliminating the danger of damaging the surface.
Churchill Paints offer two types of foam pads: with either a permanent or a hook & loop backing.For fast throughput outlets we recommend using a hook & loop foam pad with a dedicated backing plate. High quality and non-toxic glue is used in the manufacture of our pads, guaranteeing stability and eliminating the risk of foam detaching from the backing plate. All components used in the production process have been tested for non-reactivity with the compounds and is compliant with EU standards.
To find out more information about individual products, please select a category:
01260 290 666
ChurchillPaints on LinkedIn
twitter.com/ChurchillPaints
facebook.com/ChurchillPaints
